Disk brake conversion questions
adamk
Burlington
I'm in the process of swapping 3/4 axles under my XJ and have gotten to where I am working on the brakes. I have the rear already converted to Chevy disks and I'm going to be running a Dodge 2500 master cylinder. Where I'm stuck now is what proportioning valve to use? For those who have done a disk brake swap on a jeep, what prop valve did you use?
I used a universal adjustable p-valve on mine. Similar to this:
http://m.summitracing.com/parts/ssb-a0730
Common 3/8 fittings going to it and pressure switch to activate brake lights.
In reality, you can also use a WJ p-valve or from any vehicle with discs front and rear and have same effect. The adjustability is nice but not required.
