BDanque
- Mar 1, 2017
- Greensboro
I just replaced my oil pump and gasket and primed pump correctly by removing the distributor. After 30 to 40 attempts I finally got the dist back in with the rotor button lined up with the mark I made before pulling it. Cranked up and ran fine with higher oil pressure (60-70psi) which I assume is ok bc the new pump is working better. Next day cranked up psi hit 80 and leveled off. After a few minute reved lightly and boom lost psi and I shut it down. Found the dist had popped out mounting tab broken. Does anyone know what has happened here. Open to all opinions and if your in the Greensboro area maybe meet up and trade some skills( electrician). Thanks
