BallzF250
- Feb 24, 2010
- Wilmington
Alright Folks, I need some help. I've got a 1979 F-150 Short Bed with a 400 and a 4spd. I've been chasing starting issues for the past few weeks and have replaced everything in the ignition system but the distributor. Finally pulled out the one that was in there and sure enough it was seized up. It would rotate when cranking the engine, but I couldn't turn the shaft by hand once I got it out...so not good since they should almost free spin. Bought a replacement. Made sure the part numbers cast into the body of the distributor matched up before leaving the store. They're all good. This should work.
I got home and tried to install the new distributor. I previously made the necessary alignment marks, so I know where everything is supposed to be lined up and pointing and what not. I can get the distributor into the block and can get the gears to mess up with the camshaft, but the distributor remains about a quarter of an inch higher than it should be. So I pulled it back out and can see that it's not lining up with the hexagonal oil pump shaft. I've been reading around and I know about the trick to "bump" the engine (crank it) and the distributor should just fall right into place...believe me I have exhausted this method. I've reset Cyl #1 back to TDC and tried the "bump" method again...still no success.
Anyone got any other ideas/methods/options/tricks of masters for getting that damn distributor to seat onto the oil pump shaft? I really REALLY don't want to have to pull the oil pan and what not to reinstall the oil pump from the bottom side.
Oh...I've also tried the 5/16" socket taped to an extension. I can get on to the shaft and it rotates, but I'm not sure what that is supposed to do for me? I'm guessing I can try to anticipate the direction of the shaft when I install it and hope it lines up? Is that the point of doing that method?
All help is appreciated!
