HDMike
- Aug 30, 2006
- Kingsport, TN.
Ok I hope I can explain this so I can get the right answer and I hope I haven't screwed up already.
I brought some 17" steel wheels with DIY bealocks. I had posted a thread about the rings and the beads on the tires not working out.
I had noticed that Ben (Hokie_YJ) had some DIY Beadlocks he had purchased for his project buggy. There where the same bolt count as mine so I assumed that they may have been made by the same person/fabshop. they are 17" rims with 39 bolt rings, so I asked him to measure his rings and he told me they were around 18 3/4" on the OUTER DIAMETER. Now that's what mine measured but I couldn't get them down inside the bead to where I could bolt them up. So I had JD2 shave the OD down to 18 1/2".
I measured the rims and the outer ring for the bead measures 18 1/2"
I would think that ALL beads for certain size tires, i.e. 17", would be exactly the same.
So am I suppose to try to get the bolts started and they will eventually pull the ring down inside the bead or what. I hope I haven't screwed up by having the rings shaved down.
Here's a pic of what I am talking about. You can see where the ring will go down inside the bead but on the opposite side of the ring is way too far outside the bead.
