GO XJ
Member
- Nov 12, 2017
- Asheboro, nc
I'm sure at some point this has been a topic of discussion. So excuse my post if this is redundant.
I have a 1998 XJ with a 4 1/2 inch lift on 33 inch tires.
Like most of you I go wheeling as often as I can. If my alignment is correct before I entered the forest it will most certainly be off somewhat by the time I leave. My question is, what is the easiest and most direct method to set my alignment back to where it should be without taking it to an alignment shop?
I have a mechanical background and you understand the way things work but if someone has an exact measurement that will get me where I need to be that will be most helpful!
