Back when I was a tire and lube tech, I wore either Nitrile or Mechanix M-Pact 2 gloves. Now when I'm in the home garage I use HF anti-vibration gloves http://www.harborfreight.com/antivibration-gloves-large-95584.html
Ahhh someone else who uses the superglue first aid. I keep some in my truck it is amazing at closing cuts that dont want to close.
My neighbor just gave me a set of these the other day to try out. They seem to hold up better in the fingertips than mechanix gloves. Mechanix gloves are nice, but I wear through them too fast. I think I'll be making a permanent switch to the Hyflex gloves.The Ansell Hyflex gloves are the best things going in my opinion. I can do just about anything with them that I can do bare handed. Super dexterous, and they how up pretty well. A 12 pack is about 20-30 bucks.
The cuts and busted knuckles don't bother me while wrenching or at home, but I prefer to not have open wounds on my hands at my paying job in the hospital. I'll take a pass on having MRSA in an open cut.
I wear cheap leather work gloves while grinding/cutting handling metal. All the time now because of being on blood thinners.
, but use them cause Mechanix gloves will melt, BTDT I wear nitril gloves when I'm doing heavy grease packing or filthy item tear down and clean up. Example. Toyota knuckle ball disassembly or transmission tear down.
I use my mechanics style gloves for general stuff and when they get warn I cut the finger tips off and use them as needed. I've found these clean up well if I soak them in dish soap and let them air dry.. Had em get gear oil soaked a few times doing axle stuff.
I always wear gloves. Didn't used to, but I find cleanup is easier. I wear the latex or nitrile gloves most of the time unless I'm grinding or working with sharp metals. I like the mechanics gloves, but everything I work on seems to be greasy so the latex/nitrile work better. I usually wear out a set of the latex in an hour.
I'm currently using the 11-600's, and I've used the 11-801's before also. The 801's are almost like another layer of skin they are so dexterous, but the 600's are a bit more durable, and still much better than any other gloves I've used.Was doing some homework on the Ansell Hyflex gloves
http://www.ansellpro.com/hyflex/
Which type are you guys using or have had good luck with.
The oil repellent gloves 11-920 looks like it would be good in the shop when doing engines/transmissions etc.. (could have used some this weekend cleaning out a knuckle ball !) http://www.ansellpro.com/hyflex/11-920.asp
But then the the cut protection series gloves look like they'd be better with general metal work. How do these hold up to light heat ?
Matt any links/location where your ordering them from ?
