retroedaddy
Infidel
- Apr 7, 2010
- Bahama NC
I bought a 2001 Dodge Ram extended cab,it is the 360 V8 Auto trans 4x4. When I got it , it had a little miss. Well the miss got worse and I got a check engine light, so I had it checked and it was a cylinder 8 misfire. So I bought plugs and wires and replaced them. When I pulled the #8 plug sure enough it totally destroyed. The central electrode was melted and dis formed. The outside electrode was also melted and almost gone.I also took off the K&N filter and cleaned it while I was doing the work. I left the battery disconnected while I did the change. I hooked everything back up and started the truck, sure enough it still runs rough and honestly seems to be a little down on power under WOT. What would y'all check next ? I did not pull the cap and rotor, I guess I might check that next but it seems weird the plug was wrecked like that and changing it made no change to the way the truck runs.
