Does Eldorado fill up propane tanks?
spraypaintman
Greensboro
Forklift tanks that is....Eldorado Outpost? If not where is the closest place to uwharrie?
I'm pretty sure that they do not. It is not too far on into Troy to get it done, but I don't know exactly where at there that it would happen. ;)
Anybody know where to fill up in Troy?
i saw an ace hardware or something of the sort... i'd guess they probably do... if they didnt i'm sure they could point you in the right direction.... shouldn't be a problem either way though.
what would it take to be able to run gas-grill tanks? It seems that every grocery store and wal-mart has a blue-rhino cage out front. That would almost be too easy.
I have never tryed it but a diffrent end on your hose and run the tank upside down so you would get liquid instead of vapor and it SHOULD work.
also i think that the gas grill tank doesnt hold nearly as much as a forklift tank.... but if it was to get you off the trail, then carrying the adapter to make it work doesnt seem like such a bad idea
