Does it exist?
I am looking for a track rotary cutter or drag knife that uses standard utility knife blades. I need/want it to be at least 48” long. Does it exist?
I've never seen one that big that uses a standard blade, Most of them are aimed at professional sign shops and places that do large vinyl decals. They tend to be expensive, and use a round blade so they can easily cut both directions, allowing for multiple passes without moving the work peice..
What are you cutting? for such large cuts in paper, vinyl, or laminates it might be easier to make your own with just a straight edges and a stop on a table...
Here's a place that has some professional quality ones, but they start it around $500, and use a special blade...
Sign Making Tools, Rotary Trimmers - Signworld America
Do you need someth?ing cut a few times or do you need the tool fr continuous use
Straight Cutter Elite from Logan Graphics - 701-1
Logan Adapt-A-Rule 60" Guiderail - 560
Those two things combined are what I'm looking for. And the price isn't too bad. Quite a few times I've been trying to cut a straight edge with a razor blade and I end up coming off the ruler and screwing up the cut. Esp if I'm trying to make that cut deep in hard material. IE Laminate sheets or plastic sheets. This product should do the trick
