Double disc clutch issue
a_kelley
mechanical fixer
Rutherfordton
Ok so I put a clutch into an international 4700, trans went in without too much struggle. Problem is, it's not fully releasing. No clutch brake. Pressure plate is releasing, but intermediate plate is stuck against the inner disc and flywheel, but can be pried away with a screwdriver and not too much force.. Warped discs? Wrong discs? They were installed the same way as the originals, according to all labels as well. Also I can't adjust the adjuster, with clutch depressed. It's a manual adjust with lock wedge.
Faulty pressure plate, reman plate company didn't seem surprised when I said it wasn't releasing and was installed properly. Car quest would not let me tell them to get a new pressure plate, they had to call my customer since they purchased the kit. Grrrrrt.
Clutch company want surprised it wouldn't release even though it was installed properly. Car quest is supplying a new pressure plate.. Although they wouldn't take my word I needed a new one, they insisted they call my customer and get their word since they bought the clutch. Grrr. Probably will be the last time I use that particular car quest.
