double ended ram mount
Here are a couple I've built.
That's how I try to set all the ones I build. When the tires are turned front tire impacts have the most leverage on the steering components. If the tie rod and shaft of the cylinder are not in line at that point you run a greater risk of bending the cylinder shaft. Keep in mind this mainly pertains to a double ended set up.
if i were to use tube. what size would be best, my driving "style" is 'make it or break it'. not like im trying to break it, just happens hahaha
I didnt specify but i was referring to the mount. Thanks. Now i just got to find a way to bend it. Doubt my protools manual will do it.
A manual pro tools will bend 1.5 .250 wall. you'll just need a little A@# behind it lol. My buddy did all the mounts on his rockwells with a pro-tools 105 manual. If you can't do It I can just give me dimensions and I'll knock out.
You can run .120 depending on how much of it you use. The JK we race has 2 pieces of 1.5 .120 wall that go from from knuckle to knuckle, it's tied in in several places along the axle tube and it will never have a problem. .250 wall would be standard on a single tube application but other than that your dragging around extra weight. BTF and Artec make ram mounts that you can check out from a production standpoint. I'll see if I can dig one up from the JK and others we've done.
the one that artec sell if NICE but expensive. like most, i build on a budget. haha i have a bender, torch, and pretty much most of what a small fab guy would need, except the fab design haha thanks guys.
i'll see what i can order thru work. 8 ft stick should be enough.
If your budget is super tight I have a connection for some scrap 1.5 .250 wall tube. It's a little rusty but it's only like .25 a pound.
I'll check and see if there's any left tomorrow.
Chris is the magic man when it comes to hooking up on drops, I scored about $900 in sheet alum for just over $100 not long ago.....
This is one that we installed some 2" tube into the truss and then the mount is attached using 1.75 that slides into the truss for easy removal to access the diff.
Here is another Scott built for his cj on tons... this is still plenty high but allows the rigs with frames or clearance issues to sit much lower..
