Mac5005
- Oct 19, 2005
- Rocky Mount
Starting to build the front axle for my dad. Using one of ecgs ultimate hp60. Using 4wheelsupply arms and knuckle tie in kit.
Psc double ended ram.
The holes aren't drilled in the steering arms so I can put them wherever. The tie in kit allows the arm to be directly over the factor tie rod hole, so that location is available.
My question is this ,
I know the ram mounting location in reference to the tie rod mounting holes, has an effect on Ackerman,
But what's the best way to calculate where to locate the ram forward, inline, or behind the tie rod mounting centerline? And how far offset if so?
I know to match the steering angle with the ram throw, but I'd like to get the best Ackerman I can.
I'm thinking mounting the ram behind the tie rod mounting centerline would create proper ackerman, but how far?
If the ram is mounted in front of the tie rod mounting centerline, farther away from axle, this would be negative Ackerman.
Anyone have any links the address this or solid tech?
I feel like their is a good thread addressing this, but I can't find it.
Thanks.
Thanks.
