sportinanace
- Jul 2, 2009
- Kinston
Whats the best / easiest way to drain a gas tank on a 87 YJ
When the gas gets low it starts to run a little ragged I'm thinking there must be some water or something in the tank as long as you keep it full it runs fine. Any other thoughts?
If you want to check the filter sock do you have to remove the tank or is there another way
Run it as low as you can. Find a place in the fuel line to disconnect it. Add a piece of hose and run it into a gas can, turn key on and let it run the pump till it's empty. Might even want to park it, or jack it up to where the lowest part is around the pick up area in the tank
