drill and tap waggy box
biggoofy
Utah Jeeper
SLC, UT
I need on done asap who near troy Nc can do it?
Do you know of a write up on it im sure I can find a tap here at work.
http://pirate4x4.com/tech/billavista/HydroAssistTap/index.html
Should get you going in the right direction. That tap is only $6 and some change plus shipping, just FYI.
Some other helpful hints...
-pack the flutes of the drill bit and tap with some petroleum jelly, and most of the shavings will be caught
-a healthy dose of brake cleaner early and often will help rinse the rest of it out
-a generic power steering filter is cheap insurance to catch anything you missed
-after the first hole is drilled and tapped, plug it before doing the second hole to prevent anything from dropping down the hole
If you don't feel comfortable doing it yourself I can take care of it for you. Just bring me the box and I can do it while you wait.
