Drive Line Angle Help
JpDrew
Member
Martinsville, Virginia
So I have a 91 YJ with a 4in lift and a 1in transfer case drop. I'm getting ready to buy a 8.8 for it. From what I've read the pinion is about 1in lower than the Dana 35. Will my stock drive shaft angle be okay for now until I get a SYE?
X2^^ I would do it at the same time! You will have to cut and reweld the 8.8 (in less it was already done..) so you are better off to set your Pinon angle with the SYE in, plus you can get rid of the trans drop..
