After biting the bullet and getting a high angle .250 wall 1410 rear shaft, I just couldnt afford to buy another shaft. I made my front, its just a 1330 cv from a bronco shaft and I made the shaft from 1.75" x.120 and sleeved it with 2" x.120. Basically just what Kevin described. What I did was, got my length with the 1.75, welded the cv and the spline end then ground the welds down. Then drilled about 8 holes in the 2" and slid it over the 1.75 tube at the spline end, again welded both ends, and then plug welded the holes i drilled.
Ive wheeled the buggy 4 times now with that shaft, 3 times at the muddevils playground and once at URE. I use the skinny pedal pretty hard on 42"s and so far its held up great. Ive twisted the tube on 3 non-sleeved 2" x .120 shafts, once I sleeved it it has been working out great. just my .02.
