NickMaul
- Jul 4, 2009
- Norfolk, VA
Don’t flame me if this was posted recently. My driveline will be 4.0/AX15/NWF Eco Box/NP205. I have brown dog motor mounts and an IronmanFab ax15 mount. So those are pretty beefy. I bought a DIY4x np 205 case support that bolts up to the rear output housing on the 205. It uses a typical poly bushing. I was definitely planning on mounting that up right beneath the 205 case. It seems like the IronmanFab bushing allows the driveline to twist pretty freely as it is a typical poly bushing arranged in the same axis of the trans and tcase.
Does it seem like I should utilize that torque bushing mount that exists on the drivers side of the case? Trying my best to avoid cracking the bellhousing or the rear of the AX15. The 205 is so damn heavy.
TIA y’all
TIA y’all
