Driveline Vibration
ajeeperwannabe
burlington nc
I searched and sounds like most vibration is about 50mph, is this at 50 even with the accelerator pressed? I just put a 3 1/2" lift in my '87 and now have a vibration when decelerating and aplying the brakes.
__________________
*COULD* be DW, but lets examine a little.
1) Only happens on braking or deceleration, i.e. when nose heavy
2) Did this just start, right after lift?
3) Have you gone back and checked all bolts make sure everything is tight?
4) Did you correct caster with lift?
Did you replace shocks/swaybar/etc?
5) Did new tires accompany new lift?
All these are areas to look at.
If they all check out, time to start replacing BJs and bushings
