Estonian
Member
- Oct 25, 2008
- Raleigh/Garner
after my motor 4.0 conversion on my 97 jeep TJ i am getting a bad vibration when i go 50+ mph in my front driveshaft, i know it is the front because i took the front driveshaft off the jeep and i was able to go 80mph with no vibrations. The mods on the jeep are 3.5 RubiconExpress suspension lift with a 1" body lift and along with 1" motor mount lift, NO transfer case drop, and a SYE with tom woods shaft in the rear. I posted that to see if anybody thinks that with a 1" motor mount lift and NO transfercase drop, and a 3.5 suspension lift it might put the front driveshaft at a bad angle to cause vibrations??? or do you think the driveshaft is out of balance?(i did take the front yoke part off the front driveshaft with out marking which spline it came off of to replace the busted boot on it) but i dont think that would make a big difference? any input on this would be greatly appreciated.
