driveshaft ?
302ranger
raleigh/summerfield (10 min. from Greensboro)
I am about to complete my solid axle swap in my broncoII. I had to get a different drive shaft for the rear because the rear has some type of CV joint style slip yokes on each end. I got a shaft from a full size bronco with a double cardon u-joint on the t-case end. My t-case has a round flange and the shaft I got is setup to go in a flange that is similar to one on a rear axle. can I use a flange from a np 208 with my borg warner 1354 t-case?
You got some pics. I think I understand but I want to make sure. T case side is flat, and DS side is u-joint style. Does that sound right? When I got my DS it had a flat face on the side that connects to the T-case. I needed the Ujoint style. So I got a replacement that uses the Ujoint side. I have the flat side still if you want it I can mail it if it will work. It is for a 1310 U-joint though.
Shipping is free for you since I still owe you. I got it boxed and ready to go. Send me your addy. Yes it is the one for the double cardon on the t-case side. I got my motor and I am going to put it in Saturday so once it is done I will start getting the lift done so that I can get your parts to you.
