Dual t-cases on a toyota pickup
Cost can be as much as u want to spend. In my 89 I had close to 3k in my setup. But I had all the goodies. Go to marlin crawlers Web site and do some reading. Also go check out pirate 4x4 and look through the Toyota bible. It should answer any question you have if not just pm me and I'll try and help the best I can.
ok so you wont need a v6 adapter or the 23 spline input for the front case but if you wanted to upgrade he rear case to a 23 spline input you could and it would just make it that little bit more stronger. When you look at twin sticks check out frontrangeoffroad.com I like theirs better than the marlin or trail gear units, there is also a triple stick setup you can get if your tight on space.
does it matter if the 2nd case is front shift or top shift? I rarely see a top shift case for sale, and have been told the conversion shift rails (if you use a forward shift donor) are getting hard to find as well.
You can buy the conversion kit new. For the op, you can use a forward shift the way it is in the front.
