well the DRW & SRW have 2 different hubs... the spindles & stubs will interchange. You will either need to get SRW hubs or you can have the DRW hubs turned down and replace the bolts with wheel studs...
I'm doing mine this week. I will take some pics for you.
I would just buy a new set of hubs from bato zone or off ebay if I had to do it all over again.
because cutting them down is a really gangster ass way of doing it. the 8 tabs that hold the rotor on were never designed to carry the load of the truck. you also need to machine that surface flat if you are driving it at speedWhy?
I converted mine for $100 + the cost of new studs. New hubs are $189 each.
there are 2 things i do not fuck with on rigs; steering and brakes and this applies to both
I really wish that I would have just bought new hubs. I would never EVER cut another set down. I have way too much time in them and they won't be as stong as srw hubs. I also have to run a 1/2 wheel spacer to clear the non threaded shank on my wheel studs.
