mike davis
- Jul 25, 2017
- Fayetteville NC
Hello all,
I have a 2002 TJ with the inline 4 motor. 130xxx miles.
Issue I'm having, jeep wont start. And is throwing P0340 error code. Crank shaft position sensor(AutoZone says my jeep doesn't have a CPS. . .) I can hear the starter trying its hardest, but no ignition. And that's only because I Just replaced the starter, last week. We thought it was an issue with the timing on the distributor, double checked that, wasn't the issue. Tried giving a little boost with some starting fluid and now I need a new airbox from the gnarly backfire that caused.
In the last month I've (with help, lots of help.) replaced the Serpentine belt, driver side pulley, and the serpentine belt tensioner assembly, rear main seal, oil pan seal, clutch, shaved the flywheel, camshaft sensor, complete distributor, And starter. I checked my plugs and wires they are not in need of being replaced. The current engine was replaced by a shop in Alaska in 2014(15xxx miles on it.).
I have no idea what wrong at this point, and neither do my more mechanically inclined friends. Im not sure whether I need a mechanic or a priest at this point.
