guffey24
- Jun 7, 2006
- Hendersonville, NC
ok so I bought a 2005 Duramax cheap because it needed some work, guy said it might need a radiator or a water pump he wasnt sure but something was wrong in the cooling system, I bought the truck thinking I could spend a little money on it and have a nice truck
after reading on several forums I am confused and thinking the truck may have worse problems than I thought
symptoms
low coolant light comes on, coolant is coming out of the surge tank overflow tube, you can fill it up and its good for a couple days
truck does not overheat stays right around 200 degrees, no coolant and oil mixed, no white smoke, but the system stays pressureized even after the truck cools down, drove it all day yesterday came home parked it and coolant comes out of the overflow again, big puddle under the truck and the low coolant light comes back on, fill the reservoir back up drive the truck to the store come back home everything seems fine again
go out this morning try to open the reservoir and its still under pressure and starts blowing coolant out of the overflow tube, upper radiator hose is hard,
so am I looking at bad headgaskets even though the obvious signs dont point to it?
Air in the system that I am not seeing?
radiator cap?, thermostat's?
radiator, water pump?
I dont want to throw parts at this truck if it dont need it
Also if it is head gasket problems, who would you recommend as I dont have the time to tackle this?
pricing?
symptoms
pricing?
