hurt4x4
- Sep 12, 2012
- Greensboro
I have a 1990 bronco 5.8L with an e4od that seems to be having some trans problems.
Fluid level is normal and the fluid looks clean, and trans does not seems to be slipping.
At light to medium throttle the converter seems to be locking and unlocking at odd times in 3rd and 4th and it wants to shift into OD too early. It never stays in 3rd for more than 2-3 seconds unless i give it a decent amount of throttle (or have OD turned off). With heavy throttle it seems to shift fine through all of the gears at appropriate times.
Id like to look into it a little more before saying it needs a trans.
Since it seems to be related to Throttle i was thinking it could have something to do with the TPS or VSS.
I replaced the VSS and nothing changed. Should i look into testing the TPS or am i totally off on this?
