- Mar 20, 2005
- Morganton NC
I found one of these but know nothing about them. Any info would be helpful. Looking for info such as gear choices, locker availibility, Axle size/strength and so on.Thanks in advance
Chip
Chip
rockcity said:ask Brandon (bigassedredjeep), I think hes running one in his CJ
i've got all the 14 bolt stuff in mine, detroit, shafts, BTF bolt on caliper brackets(the spacers have to be cut down), 1/2 ton calipers/rotors, spring perches, and u-bolts/plates. they have a 1350 (u-bolt style) yoke.
) pretty sure that the stock shafts are 11 spline not 16. here's most of the threads from pirate:2KFLEXJ said:These came in the 3/4 and 1 ton fullsize chevy's from 67-72? Cause I think if thats the case I've got 4 of them?
Preferrably open diff.Rich said:I'd be happy with a 4.56 one..Preferrably open diff.
upnover said:So???? You are saying the 14 bolt gears will bolt right in? No machining?
When you cut the bottom, do you have to turn the ring gear also?
)...and depending on how much you shave it, will determine if you turn down the ring gear. i only shaved the housing up to the ring gear, didn't feel like messing with that.
