ECGS 14 Bolt Disc Brake Conversion - SRW
Cperry
Durham, NC
This is a complete bolt on kit to upgrade your drum brakes on your 14 Bolt to disc brakes.
Kit Includes:
Single Rear Wheel 3/8 Bracket
Mounting Hardware for Brackets
Left and Right 1/2 Ton Calipers
New Brake Pads
New 8 Lug Rotors
Two 12" Long Braided Stainless Lines
24" And 18" Long Hard Lines
Mounting Hardware for Brake Lines
Hub Seals
Hard brake lines only come flared on one side to accommodate for different vehicles and brake line set ups. Some grinding may be required on caliper based on how brake lines are run. No provision for e-brakes.
THIS KIT WILL ONLY WORK ON SINGLE REAR WHEEL APPLICATIONS!! DOES NOT WORK ON 1989 AND NEWER AXLES! $325 shipped with stainless lines.
We also have a universal weld on kit with Weld On 3.25" Diameter Brackets that is $320 shipped.
NC4x4 Members discount code is "BRAKES" for the Bolt-On kit and "UNIVERSAL" for the Weld-On kit.
Both products can be seen here Universal 8 Lug Disc Brake Kit - Rear Only and here 14 Bolt Disc Brake Kit
1st pain in the ass request: Would it be possible to list the mounting hole dimensions of the bracket so I can measure my axle (not a 14bolt)
2nd pain in the ass request: What is the measurement at the greatest radius from axle-shaft centerline to top of supplied caliper?
PM if necessary, or to cuss me for asking
Thx!
Kit Includes:
New Brake Pads
New 8 Lug Rotors
Hub Seals
Kit Includes:
New Brake Pads
New 8 Lug Rotors
Hub Seals
