And you save on the shipping! I'll need to buy the front, and the master install kit. Most likely the labor to install as well.
For my JK with the D30 front.
ARB CKMA12 Air Compressor Features: * High Output compressor will inflate a 35 inch tire @ 8psi a minute * These compressors are hand wound, fully tested before packaging, and built to Ausi military specs * 2 year warranty w/ replacment parts available
* Watch live ARB CKMA12 air compressor video
Price: $245.00
$629.91
Part Number: KIT493200N1987-95 YJ WranglerManual or power steering4 shocks and boots includedTrack bar relocation bracketMax Tire Size: 31x10.50Does not include pitman armOur leaf springs have been engineered to give you one of the best rides on the market today! Tapered ends, Teflon slide pads, presetting, bolt and cinch clamps. All of these elements have been put together giving a ride that you won't believe. The hydraulic shocks with their velocity sensitive valving have been fine-tuned for each application ensuring a smooth ride. Four Wheel Drive Hardware's lift kits come complete with everything you need for installation. Kit includes: 4 leaf springs and U-bolts, 4° Urethane spring and shackle bushings, 4 hydraulic shocks with boots, front and rear track arm relocation brackets, front and rear brake line relocation brackets. 4Wheel Drive Hardware recommends the purchase of the slip yoke eliminator kit and new rear drive shaft for YJ and TJ vehicles with 3 or more of lift to keep optimal performance level. All lift kits and suspension systems require a shipping surcharge of $24.95.
Thanks for the chance and congrats on business expansion. That's a real good thing to hear these days. I'm in for the RS60c- D60 diff. cover. Thanks again, I've been good this year...
