mudcrewsr
Member
- Sep 18, 2012
- Wilmington NC
Hey guys I have a mark viii fan that I am installing in my TJ (just finished the dodge 5.9 motor swap). I've been looking at different controllers and I wanted to ask you opinions of what has worked for you for fan controllers.
I looked at the painless performance F5 Single 70amp controller but they were too expensive and I didn't like the idea of the plastic adjuster screws... I've seen a few comments where they can break.
I've also seen the Dakota Digital controller . This thing looks pretty nice for around $110
What are you guys using/doing for a fan controller? Does anyone have any experience or comments on either of these controllers?
May main goal and need is I need a continuous relay 70amp, I'd like to be able to turn the fan off when needed and I want a controller that will have a low temp setting kicking the fan on at 50% juice (say at 185deg). and then running the fan at 100% juice when up to temp (220deg)
Both of the above mentioned seem to do this but I wanted to know if there were other controllers to look at or if you guys had other ideas or suggestions.
Thanks
Thanks
