mudcrewsr
Member
- Sep 18, 2012
- Wilmington NC
I'm attempting to install my electric fan today but I'm stuck. I've never installed electronics with a relay before and I'm getting confused on what to ground or what to return back to the negative post on the battery.
This diagram is what I was going to attempt. wiring
My question is first of all is this a correct diagram?
Second question is if this diagram is correct what do I run the neg. post from the fan to? Most stuff I have seen online says ground. Does that mean ground it to the body or frame or does it mean run the negative to negative post on the battery?
The relay is tripping me up in the past I would have just made a loop from switch to fan to battery but I want to do this right and not burn myself to the ground.
Any suggestions or guidance is appreciated.
Thanks all!
-Randy
Thanks all!
-Randy
