Presbuteros
- Mar 27, 2008
- Wake Forest
I like this idea:
link
I found a guy with a 2 gallon tank that only has one hole/port. Can I use said tank, put a 5:1 manifold on it and feed the air input, unregulated output, adjustable regulated output, pressure switch, and safety regulator valve through it and it function properly?
My assumption is yes, but wanted to check before I buy said used tank.
There is a good picture of the air manifold example here. He has a separate port for the input from the compressor, my tank would not. I would input from the compressor into the manifold.
link
