YotaOnRocks
- Jul 17, 2007
- Madison
It seems the on/off switch has burned up. I called and they are sending a replacement but it will be a couple weeks before it gets here.
My question is. The old switch had 20a on the side so I'm assuming it is rated at 20a. It has 3 prongs on the back with wires attached. Can I just pick up a switch from Lowe's that is rated for 20a and make it work until the one that fits in the cabinets hole comes in.
Also I checked the wires and the red one had 120v when checked against the black or white wire or a ground. The black and white had continuity(pretty sure that's what I mean). What wires should I jump to make sure it is just the switch.
Here is a pic of the back of the switch if it helps any.
