RatLabGuy
- May 18, 2005
- Churchville, MD
I'm building a very simple circuit and need a little help.
Lets pretend you have several LEDs connected to a single power source (in parallel), each is switched on/off via a relay.
The power source is 12v, so it needs to be dropped to be usable by the LEDs (5v max, 2.2v min). I want to be able to manually adjust teh intensity of the LED light, so I was planning to just use a linear potentiometer to do that.
One thing I wonder about thoughis what will happen when multiple LEDs are turned on. Will the added resistance cause a drop in the available voltage (behind the pot), and hence affect the luminance of other LEDs?
If so, would using variable linear voltage regulator be better than the pot? What's the advantage/disadvantage of each?
