Will Carter
- Mar 23, 2005
- Burlington
1983 Toyota pickup 22R with around 240K
So I popped the valve cover to adjust the valves on the new rig in progress to find sludge caked on pretty good. Good news is that when I swapped the oil pan from a 2wd to a 4wd the oil pickup was clear and minimal sludge in the bottom/oil pan.
My question is...If I remove the oil pan and let it all drain out the botom, do you think it would be safe to wash (brake clean) the sludge down the passages without lodging some of it in a crucial oil galley?
Only thing I've found on a quick search is everyone taking apart engines to clean sludge...I don't want to do that right now...
The motor seems to run fine...but was just a little noisy...
