Engine Test Stand Design
J.C.
Volunteer
Moderator
Greensboro, NC
Working on an engine test stand to get the SBC 350 ready for the swap. Here's what I cobbled up today. More pics after I get the engine on it.
:popcorn:
Easy enough to see where your engine will mount to, are you gonna have something to mount the rear of the engine to? or are you gonna have a tranny hooked to it? Radiator? or just not got that far yet?
Patience grasshopper :) Finished mounting the radiator last night, still a work in progress.
John, are you gonna run that motor on that thing?! Good luck my man, just dont blip the throttle. I would be concerned that it would tip over. It looks fine for a stand IMO.
should be fine, i would have made it a bit wider, but it will work.. I made one many years ago back in highschool, it was out of angle iron. Small rad. upfront, small, 'dash' with a few gauges, really made it easy to get the came broke in and fiddle with things (as I was learning).
Will definitely make doing your TBI setup, cake...
John, when that motor flips over when it fires/ stumbles from sitting a while, give me a call, I will have another one out soon! Seriously, watch one torque on startup while its bolted in a chassis and give it some consideration. On another note, I have lots of brackets for you if you run into fitment issues around the steering etc.
Looks like the start of a home-grown tube chassis.
You could put this whole setup in the middle of a John-boat, and run a driveshaft straight from the crank to a propeller...that would be bitchen!
Looks great John!
Got the engine mounted today. Rolls around good. Now I need to get a fuel pump, some rad hoses and see if this baby will run :) Jeff, you can see the bracket mounted on the bell!
