mbalbritton
- Mar 22, 2005
- Lakeland, FL
Is this something you need to know for practical use or for class?
That's what she said...As in the pole on the right is ovbiously a little longer than the one on the left?
They are geometrically the same from a resultant force standpoint. The one on the right should be a little stiffer due to the bends, and more stable because of the lower center of gravity. Thicker material leads to less difference in the stiffness, thinner material leads to less difference in COG.
Also, the added length of the pole on the example on the right would allow it to bend easier.
I am no engineer, so my thoughts on this are uneducated. But my inclination would be the one on the right. My reason would be that with the extended pole going below the caster. It increases the amount of rotation needed to reach the break over point to where it would be tippy.
then I think about a Z-bar draglink. It doesn't matter how you get from the pitman arm to the knuckle the Moment arm is still the same.
With regards to SkyHiK5's answer what if you replaced casters with rubber feet?
