redneckjeep87
Landscaper Extroidanaire
- Oct 10, 2007
- Woodleaf, NC
I have some tractor hydraulic implements that I am wanting to convert over to run off skid steer hydraulics. 3pt backhoe as well as a log splitter and I'm sure there will be others down the road.
All the implements I am dealing with are 2500psi max cylinders. Have already blown quite a few seals even at idle.
My current machine pressure is 3700 psi with 3 stage flow rate of 3gpm, 13gpm, and 16gpm. It has the standard 2 flat face skid steer couplings as well as a case drain.
I need some sort of pressure reducer setup that ideally I can utilize between multiple implements. Would be great if it was a seperate entity that plugged into both and I can just build a mount for it to sit on opposite loader arm or on the implement.
I know that it is plenty doable, just need to find the right hardware and information. Local hydraulic shop I went to wanted to do some crazy convoluted shit inside my machine with electric over pressure regulators etc etc so I walked to out. It shouldn't be that difficult. Another told me to adjust the pressure relief on my pump when needed and screw that. I swap implements too often on jobsites for it to be that time consuming.
I do have double acting hydraulics so I assume would need to have some sort of one way check valve on the "return" end due to valve block on the backhoe being one directional.
With a pressure reduction From 3700 to say 2350 or 2400 to stay under the 2500psi cylinder pressures, would the excess pressure need to return via the case drain?
I have done quite a bit of looking around on the subject but noone has the info that pertains specifically to my situation for some reason. Also not looking to screw anything up with my 50k machine by going by some hack job bubba on Facebook or down the road told me to do. I trust yall which is why I am posting here. Lots of smart mfers in here.
Machine is a ditch witch sk1550. Out of warranty, paid off next month....finally, not that that part matters.....but wooooooooooo!
