Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
I was thinkin more along the lines of cutting the larger tube in half and welding it on the bottom half of the tube as a kinda skidplate
I've alway's been concered about that w/ my exo. Is there anything else you can do to make it laterally stronger, other than running it through the cab.
Dave
By the time you do that....the cost of the 2 different sizes of tube + welding wire and gas + cut wheels, torch, plasma (whatever you use) + the time you spend doing it....
I would just get a thick piece to start with.
Seth
ive seen alot of cages built with the old school northern pipe benden and it looked good... plus u can beef the guns up in the processGet pipe at a salvage yard, such as D.H. Griffin here in Greensboro, CHEAP!
Usually, yes. But sometimes they will not slide inside without ALOT of force.
