livetorun
Mammary Enthusiast
- Jul 20, 2008
- Louisburg, NC
Has anyone put an external fuel pump on a TJ, specifically an 05 or 06? My stock pump needs to be replaced and I'd rather do an external setup if possible. I have an RCI fuel cell in the back if that makes a difference. The 05-06 models run around 59 psi fuel pressure. I read on pirate that a WJ external filter/regulator can be used and it has a return line built into it that can easily be routed back to the tank. So, if that will work, I only need a pump that will supply the right pressure. Walbro makes an inline pump that supplies 255 lph which I believe is the same as the factory pump. Anyone tried this setup or think of anything I'm overlooking?
), it'll bleed off the difference in unused/unneeded pressure/flow...
