Ok I put detroits ez locker in the rear of my 44. The thing won't stop popping while going STRAIGHT down the road. All the springs were installed w/ caps towards the pin as instructed. Had even spacing. Spider gear trust washers were put on the side gears. Tire pressure is the same. Clicks when going in circle under no gas(Which is good) Tires chirp when under power. But the thing won't stop poping, buckin the rearend, when going straight. It gets louder/harder when under more gas. I've opened up the diff cover again and check everything, everything checks out to my best understanding TracTech is closed for the weekend, so I wanted to see if anyone could help me.
