milehighf150
- Nov 7, 2009
- Harmony NC
I've got a 86 f150 with a rough country 6" lift kit on it. I took i today to get an alignment and was told that the camber was to far out to be adjusted by the stock setup. it was showing -1.4 and needs to be +3.0 therefor i would need to buy camber bushings that adjust to approx. 4.0 degrees. the problem is they don't seem to make them in that size. the guy that owns the shop said to move the axle pivot bolt up to the other hole in the bracket, which according to the instructions is for a 4" suspension lift, and that should correct the camber. The guy that doing the alignment, also the guy that helped install the lift, said that that might bind the front axle being it is a IFS truck. Please help! i don't want to spend another 120.00 bucks on parts right now. Thanks in advance
