Carolina Cummins New Member Joined Aug 9, 2006 Location Hudson Feb 4, 2007 #1 I have a 1984 toyota truck. The heater fan barely blows, it sounds like it is blowing hard but the air is coming out of the vents.
Blkvoodoo professionally useless Moderator Joined Mar 16, 2005 Location Archer Lodge Feb 4, 2007 #2 Does truck have AC? you probably have a lot of crap and crud in the HVAC case, or a door inside that is stuck. Do you have all fan speeds ? should be 4 speeds and off. Are you able to move the mode door selector with no effort ? or maybe too easy ?
rattlecanpaint Well-Known Member Joined Apr 18, 2005 Location Winston Salem Feb 5, 2007 #3 Actually 3 speeds and off, but pull the blower motor out. It's under the glove box. Really easy to get out. It's probably full of leaves and stuff. When I bought mine it was so full of crap that the blower was off balance.
Carolina Cummins New Member Joined Aug 9, 2006 Location Hudson Feb 5, 2007 #4 I just installed the A/C evaporator, fan, and other junk in the truck. The fan must be weak. I'll pull the motor back out and install another one.
Blkvoodoo professionally useless Moderator Joined Mar 16, 2005 Location Archer Lodge Feb 5, 2007 #5 check the blower motor resitor pack also, those ar ea known common failure point. Also, open the motor, the brushes may just be worn out ( they are replacable, just gotta know where to look)
