This might help
THIS BULLETIN IS BEING PROVIDED IN ADVANCE. DO NOT ORDER PARTS OR
PERFORM ANY ACTIONS RELATED TO THIS BULLETIN UNTIL JAN. 20, 2003.
SUBJECT:
Newly Released Solenoid For DTC P1499 - Hydraulic Fan Solenoid Circuit Fault
OVERVIEW:
This bulletin involves the replacement of the hydraulic fan solenoid instead
of the complete cooling fan module.
MODELS:
2001 - 2004 (WJ) Grand Cherokee
2001 - 2004 (WG) Grand Cherokee (International Markets)
NOTE: THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A HYDRAULIC
COOLING SYSTEM (SALES CODE NMH).
SYMPTOM/CONDITION:
The customer may experience a MIL illumination due to DTC P1499 - Hydraulic Fan
Solenoid Circuit. The MIL illumination may occur intermittently.
DIAGNOSIS:
1. Proceed with this bulletin only if the cause of the MIL illumination is due to
DTC P1499 - Hydraulic Fan Solenoid Circuit Fault.
2. Refer to the 2002 or later Jeep Grand Cherokee – Powertrain Diagnostic
Procedures Manual to properly diagnose DTC P1499.
3. If the diagnostic procedures determine that the hydraulic fan solenoid is
at fault, then perform the Repair Procedure.
NOTE: THE HYDRAULIC FAN SOLENOID LISTED BELOW HAS BEEN RELEASED
AS A SEPARATE ITEM. THE COMPLETE HYDRAULIC FAN MODULE NO LONGER
REQUIRES REPLACEMENT WHEN ONLY THE SOLENOID IS FOUND TO BE AT FAULT.
PARTS REQUIRED:
Qty. Part No. Description
1 05102210AA Solenoid, Hydraulic Fan
07-005-02 -2-
EQUIPMENT REQUIRED:
CH6000 Scan Tool (DRB III®)
CH7000/7001 J1962 Cable
REPAIR PROCEDURE:
1. With the engine off, disconnect the negative battery cable from the
negative battery terminal.
2. Raise the vehicle on a suitable lift.
3. Clean the immediate area around the hydraulic fan solenoid of any debris.
4. Disconnect the electrical harness from the hydraulic fan solenoid (Fig. 1).
5. Have the new hydraulic fan solenoid ready for installation. Make certain that the two
o-rings are in place. Notice that the armature of the solenoid can rotate within the body
of the solenoid (coil). A T40 torx bit is used for removal and installation (Fig. 2).
NOTE: IF THE SOLENOID REMOVAL AND REPLACEMENT STEPS ARE PERFORMED
QUICKLY, THEN ONLY A VERY SMALL AMOUNT OF STEERING FLUID WILL
DRIP FROM THE FAN MODULE HYDRAULIC FAN SOLENOID OPENING.
THE SMALL AMOUNT OF LEAKAGE SHOULD NOT REQUIRE PRIOR FLUID
REMOVAL FROM THE POWER STEERING RESERVOIR.
6. Hold the connector of the solenoid to prevent the solenoid body from turning, and
remove the hydraulic fan solenoid from the hydraulic fan module.
7. Immediately install the new hydraulic fan solenoid. Tighten the
solenoid to 16.2 Nm (12 ft. lbs.).
8. Connect the electrical harness to the hydraulic fan solenoid.
NOTE: IF FOR ANY REASON DURING THE REPAIR PROCEDURE THE
ELECTRICAL GROUND WIRE IS REMOVED FROM THE HYDRAULIC FAN
MODULE ASSEMBLY, THEN RECONNECT THE GROUND WIRE AND TIGHTEN
THE RETENTION NUT TO 10 NM (7.4 FT. LBS.). FAILURE TO ENSURE THE
GROUND STRAP IS PROPERLY CONNECTED COULD RESULT IN ELECTROSTATIC
DISCHARGE THAT MAY DAMAGE THE PCM.
9. Lower the vehicle.
10. Connect the negative battery cable to the battery negative terminal.
11. Verify the fluid level in the power steering reservoir. Top off the fluid level as necessary.
