Fasten rock sliders to frame
CThurmond
china grove nc
I bought some used rock sliders off the board , they did noy include the hardware
They each have 3 arms with 4 holes for fastening to the frame
Whats best way to attach?
its for a 93 zj
Sent from my HTC Glacier using Tapatalk 2
Just just self tapping screws??
yep, the legs to the frame rail are just big self-tapping screw/bolts. my rails have a flange along the pinch seam, uses 1/4" nut/bolts.
Why don't you ask the PO how yours were fastened?
He didnt have hardware he also bought used but he nevrr installed,
Mine has same pinch seam suppor
Guess ill do that all tonight, shoukd be simple if thats all, should I lock tit it
I bought some sliders from KOR for my other ZJ, I also used self tappers into the uni, but after a while they started coming loose, so I had the feet welded to the uni. Granted I banged on my sliders a lot, and they were beat to crap to show it. Also think about attaching it to the rocker pinch seam to control some upward movement.
When we held them under your zj yesterday I showed you where they connected. I told you to use self tapping screws on the arms and nuts and bolts to the rocker pinch seam. I was trying to explain more but you had to rush back into work.
Sent from my microwave using a teleportation device.
Ya sry boss wasnt in best of moods yesterday when you dropped them off, but I got idea now so ty for input guys
Hah got one on after 3 hours of work, the pinch seam support is In the worst position ever to try to line up the pre drilled holes
Putting mine on the FJ next week & I wouldn't do it any way but with a welder.
Weld them on and forget it.
How many people ever actually take them off?
I went to a lot of trouble to make mine removable... 8 years ago... never had the need to take 'em off, and now they are part of a roll CAGE SO THEY ARE WELDED ANYWAY.
I'd like to see pictures if possible.
cory if you want i have access to a welder. boltthem on then get up with me and we can work something out.
