ff 1 bolt into 91 chevy 1500
nckrawler
kannapolis
what is the easiest way to take off the old spring perches and relocate on the 14 bolt ? the spring on the 91 chevy are ab 5 inches narrower..any help would be apreciated
With a magnetic degree finder. Sears has them for about 10 bucks.
thanks for the help now some steering ?s....i know i can do a crossover steering but i have a 8 lug 10 bolt with a driver side steering arm already on it and I've seen a steerin setup using the ifs steering box and the tie rods? anyone know how to actually set this up? or has anyone seen this before?
you need a flat top knuckle that is just like the driver side. Have it milled flat and drilled for the three studs. Look on ebay for crossover steering. There is a company that you can send your knuckle and they will do this for you for around 50-60 bucks. They also have the other parts to finish it too.
