FJ-40 axle pinion's, fine spline same as???
Go register on ih8mud.com, you should be able to find what you need on one of the tech boards.
standard mini-truck axle flanges will work. That is what used when i swapped dads on the buggy. For that matter, gear t-case flanges will work if you knock the dust shield off. They are all 27 spline.
SEth
