Jeepj10
- Aug 19, 2009
- Asheville/NCSU
I just got this 80, its a 91 with about 180k on the clock. Heres the problem that Im having. if the engine is cold it will start right up fine and run great no lights on the dash or anything, however if I turn it off an turn it back on while the engine is warm the A/T Oil Temp light comes on and it wont start, it sounds like it is starved for gas. Any ideas what this could be? Does this light/sensor have a switch that will cause the truck to not start? would there be a chance that is going bad?
Thanks for all the help in advance!!
Ben
Someone on another forum said this light may come on at each startup and I may be having other problems. Im thinking if this is the case its maybe vapor lock?
Ben
