XJsavage
CounterCulture
- Aug 15, 2009
- Lyle's Ford SC
I have an NP205 transfer case behind my 4l80e automatic that I've clocked completely flat. Specs say that they take 2-2.5 quarts of gear oil to properly lubricate it. When you look at the fill line on a stock clocked transfer case it about halfway covers the front output gear and bearings within.
Example:
And here is where I'm at with exactly two quarts of Amsoil 75-120 synthetic, only about an inch covering the bottom of the front output gearset.
So should I keep adding more until the oil line covers the halfway point of the gear? Or is that too much? I have two more quarts I can add if need be.
This vehicle will get driven at highway speeds in 2hi for several hundred of miles at a time up to 85 mph, (I mean 70~speed limit), and drag raced every blue moon. Will also be driven in 4-hi/lo for extended periods of time as well.
Example:
