Flush Mount Lower Triangulated 4 Link Bracket
Barnes 4wd
Etowah NC
If you are looking to have a dual triangulated four link suspension then this is the bracket for your project. Our Flush Mount Lower Triangulated 4 Link Bracket is cut from ¼” A50 Plate and is made to take tons of abuse. What makes our bracket different from our completion is that our bracket does not hang down any lower than the tube that it is welded on and you do not have to drill out the holes for your bolts. This allows you to keep your flat belly and not have an anchor hanging down tight in the center of your rig! This bracket is cut so that it will self jig to a 2 5/8” mounting width and a 20 degreeIf you are looking to have a dual triangulated four link suspension then this is the bracket for your project. Our Flush Mount Lower Triangulated 4 Link Bracket is cut from ¼” A50 Plate and is made to take tons of abuse. What makes our bracket different from our completion is that our bracket does not hang down any lower than the tube that it is welded on and you do not have to drill out the holes for your bolts. This allows you to keep your flat belly and not have an anchor hanging down tight in the center of your rig! This bracket is cut so that it will self jig to a 2 5/8” mounting width and a 20 degree
http://www.barnes4wd.com/Flush-Mount-Lower-Triangulated-4-Link-Bracket_p_242.html
