yjkimrey New Member Joined Oct 31, 2005 Location albemarle, high point Nov 22, 2005 #1 what do most ford 8.8s come geard stock
BUCKETOBOLTS Member Joined May 4, 2005 Location Faith, NC Nov 22, 2005 #2 Guess it depends on what it came out of? Most pass cars would probably be 2.73 or 3.08. Then I believe Explorers and trucks are 3.42 or 3.73.
Joel Well-Known Member Joined Mar 20, 2005 Location Winston-Salem, NC Nov 22, 2005 #3 Not sure if this helps you any but: Code Capacity Ratio 43 Open 3200 3.08 41 Open 3200 3.27 42 Open 4.10 46 Open 3.73 45 Open 3200 3.55 D4 Limited Slip 3200 3.73 D2 Limited Slip 4.10 L73 Limited Slip 3.73 L - Limited Slip Differential C - Conventional Differential http://www.webwheeling.com/index.php?ind=articoli&op=entry_view&iden=10
Jeepnmud74 New Member Joined Jul 14, 2005 Location Mount Holly, NC Nov 22, 2005 #4 I think they have a lot of different ratios.
Elliott Well-Known Member Joined Mar 20, 2005 Location San Diego, CA Nov 22, 2005 #5 depends on what you get it out of. 3.54, 3.73, and 4.10 are common.
getstucksome Well-Known Member Joined Nov 7, 2005 Location Charlotte/Mt. Holly area Nov 23, 2005 #6 4.10s are harder to find, at least when i was looking. they came with the tow package if i'm not mistaken
Exploderpilot Well-Known Member Joined Mar 24, 2005 Location Winston Salem, NC Nov 24, 2005 #7 if you find a Fx4 ranger they had 4.56 optons available with the 5 speed and the FX4 also has the 31 spline shafts.
ProjekTJ Well-Known Member Joined Mar 23, 2005 Location Salisbury Nov 25, 2005 #8 Mine was out of a 97 or 98 Explorer. Came with 4.10s, Limited slip, and 31 spliners. Now it has 4.88s, Detroit, and 31 spliners. If you need a certain set of gears for it call Andy at Carolina Rock Shop...he's probably got some laying around.
